It is currently Sun Jul 27, 2025 2:47 am
PostPosted: Wed Jul 20, 2005 11:11 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Does anyone know about this gun, used it or used any comparable Wag. system.
PostPosted: Fri Jul 22, 2005 11:38 am
Bob, I have the Wagner Fine Spray ULV system. I have only tried sample sprays so can't give you a full endorsement. From a novice viewpoint I was happy with the results. I'm sure it is not as good a system as the FUJI's and Accuspray with the three stage turbine systems. I started out trying to buy everything at once on a limited budget and the price was right. However, a couple of years into this, I'm replacing a lot of the bargain equipment with better quality. If you are going to be into building long-term, I'd suggest saving up for a better system (based on my experience with bugdget laminate trimmers, bandsaws, etc.) I still think they will work okay but may require more work to get a level surface. I still plan on trying mine when I get around to finishing rather than just building boxes
